4l60e p1870 code - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-16-2008, 01:01 PM
4l60e p1870 code
I have a 1997 chevy k1500 pickup with a tci truck master transmissiom that just started setting p1870 code. This trans was installed in 2005 and it has about 85k miles. fluid does not smell burnt and I have been driving the truck in 3rd gear only. A local GM dealer tech gave me a diagram tha shows drilling a 1/8 inch hole in the bore plug that caps the regulator apply valve, regulator apply spring and isolator valve. Has any one else seen this or heard of this.
Old 11-16-2008, 07:23 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
I install the TransGo kit SK4L60E , the kit contains a re-designed valve for the PWM system. Works well as long as the converter clutch is not burned up already.
Old 11-17-2008, 12:40 AM
Crosley Do you have to drop the valve body to install this kit?
Old 11-17-2008, 05:13 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
yes , the v-body is dropped. This kit includes several upgrades in it. The boost valve is dropped out of the pump too.
Old 11-21-2008, 03:21 AM
Crosley thanks for the info v-body had a lot of ware did what you said shifting good & tcc is locking up and holding.
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
Unidentified GM engine code Crazy Fast on Ice Engine 1 10-05-2008 06:09 PM
GM 4L60E with code 28 ironpumper Transmission - Rearend 5 12-29-2007 04:11 PM
Another P1870 code thread ihateP1870 Transmission - Rearend 6 12-16-2007 05:32 PM
TCC error code P1860 in 4L60E tranny PilotHawK Transmission - Rearend 19 10-18-2005 02:26 PM
