-   -   4L60E Pan Bolt size (http://www.hotrodders.com/forum/4l60e-pan-bolt-size-131165.html)
ikaika33bambam 01-08-2008 06:46 AM
4L60E Pan Bolt size
Anyone know the correct size bolt and thread for the transmission pan? Thank you.
Crosley 01-08-2008 05:06 PM
10mm x 1.5 thread pitch.
it is a metric trans, all bolts are metric.
:D
EDIT: pan bolts are 8mm x 1.25 pitch...
tail housing are 10mm x 1.5, as is the mount bolt holes, the shift shaft threads
sorry for my mistake in this years ago
:pimp:
ikaika33bambam 01-08-2008 05:08 PM
thanks, I appreciate the help.
Crosley 01-08-2008 05:13 PM
appologies.. the size for the pan is 8mm x 1.25 thread.
I was thinking tail housing
327amc 04-14-2012 09:50 AM
Thanks for the info.
I gotta order a helicoil.
