4L60E Pan Bolt size - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-08-2008, 07:46 AM
4L60E Pan Bolt size
Anyone know the correct size bolt and thread for the transmission pan? Thank you.
Old 01-08-2008, 06:06 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
10mm x 1.5 thread pitch.
it is a metric trans, all bolts are metric.
EDIT: pan bolts are 8mm x 1.25 pitch...
tail housing are 10mm x 1.5, as is the mount bolt holes, the shift shaft threads
sorry for my mistake in this years ago
Old 01-08-2008, 06:08 PM
thanks, I appreciate the help.
Old 01-08-2008, 06:13 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
appologies.. the size for the pan is 8mm x 1.25 thread.
I was thinking tail housing
Old 04-14-2012, 10:50 AM
327amc's Avatar
Owner of a broken cart
Thanks for the info.
I gotta order a helicoil.
Z-28 Windage Tray / Oil Pan Clearance Issues ezobens Engine 1 03-25-2007 02:48 PM
power glide pan capacity aluminum pan jsteve068 Transmission - Rearend 2 02-22-2006 07:42 PM
4L60E pan bolt torque? macx Transmission - Rearend 0 07-20-2004 12:41 PM
tv cable bracket bolt size help 39chevy Transmission - Rearend 1 04-14-2004 09:01 PM
4 Bolt Block HotRodS10 Engine 16 05-21-2002 07:27 PM
