4l60e pics... - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-21-2007, 07:54 AM
8843astro's Avatar
4l60e pics...
This is from a 94 suburban with 160,700mi on it. It quit working and finally decided to take it apart and look inside. I've never done tried anything like this before and it's been a real good learning experience. I bought the 4l60e rebuild dvd and that's what I used to help me with the disassembly. Still learning the decription of the parts.
Here are some pics of the damaged parts.....
ID:	18712   Click image for larger version
ID:	18713   Click image for larger version
ID:	18714   Click image for larger version
ID:	18715   Click image for larger version
Old 02-21-2007, 08:53 AM
4L60E pics
Hopefully your dvd will show you how to check the clearance in your trans.
Looking at the damage to the bearing [on top of input drum] clearance may have been an issue.
Are you starting to put it back together yet?
Please keep us informed about your progess.
Old 02-21-2007, 08:55 AM
8843astro's Avatar
Still in pieces. The video does cover clearance's but I'm still waiting for the books to show up. Let see how it goes...
Old 02-21-2007, 05:56 PM
airworld2's Avatar
4l60e
What I see is typical stator bearing failure, the needle bearing after failure will cause reverse input plates to stay applied all the time and the clutch lining shell's off steels plates and trash drum, input drum should be replaced along with stator shaft. look at the end of pump shaft (stator) and you will see damage too. end play isn't the cause of this failure, bad bearing is!!!! I see this all the time from 1993 units to 2004 thank god too......
airworld2
re-arrange pics in photo album ChevelleSS_LS6 Hotrodders Site Suggestions and Help 7 01-25-2013 07:54 PM
54? Chevy sedan ChevelleSS_LS6 Hotrodding Basics 27 06-12-2005 02:11 PM
Pics of the Spider vorgath Body - Exterior 3 12-02-2004 07:13 AM
pics again helrazr3 Hotrodders' Lounge 16 09-20-2004 06:40 AM
Completed Stude interior pics... phattpat Interior 6 07-22-2004 11:03 AM
