4l60E pressure regulator boost valve - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-05-2009, 03:23 PM
impalaman63's Avatar
Found this on the net.
The pressure regulator boost valve and it's sleeve should be replaced every 40,000 miles to avoid major damage that occurs when accumulated wear in the boost sleeve causes insufficient pressure to be made available in reverse. We are seeing too many major repairs of the 4L60E at around 50,000 plus miles being traced to this boost valve and sleeve. The valve and sleeve can be replaced easily during a routine service of the transmission at an additional cost of around $50.00. This should be considered a must do maintenance procedure on the 4L60E.
Is this a easy fix.Like drop the pan and replace booster valve?
Old 01-06-2009, 08:11 AM
SSedan64's Avatar
Yes these are easy to change when the pan is removed. They're located in the bottom of the pump housing at front of trans. Just need to select the correct type. Pressure regulator valve, TV boost valve & Low/Reverse boost valves are seperate pieces.
http://www.sonnax.com/part_summary.php?id=3592&pl=3
http://www.sonnax.com/part_summary.php?id=4247&pl=3
http://www.sonnax.com/part_summary.php?id=3594&pl=3
http://www.sonnax.com/part_finder.ph...637&go=GO&pl=3
Correct way to set valves on sbc w/ solid flat tappit camshaft? Joshua Lee Engine 17 02-09-2011 06:55 PM
cam question, any truth to this? 406 ss monte Engine 6 03-30-2008 12:28 PM
4l60e boost valve difference???? 8843astro Transmission - Rearend 5 03-24-2007 01:37 PM
4L60E Line Pressure problem (possibly) olimpalarider Transmission - Rearend 13 11-20-2006 03:55 PM
Granada Swap into 69 Torino blacksunshine Suspension - Brakes - Steering 32 10-04-2006 07:24 PM
