4L60E problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-30-2012, 11:35 AM
4L60E problem
I had the 4L60E tranny of my 2001 Tahoe rebuilt by a friend. He is doing trannies for more than 30 years, but he is only familiar with the old-style mechanical transmissions. There was a bad bearing and clutches and the brake band was worn out.
After I put the tranny back in the car, it did not shift propperly. I found out that the big round connector was not connected properly, after I fixed that and erased the error codes in the computer, no new error codes showed up but the transmission still doesnīt shift as it should.
When I shift in OD or D, it stays in first, when I shift in 2, it shifts up to second. Reverse, neutral and park works properly.
Mechanical the transmission should be fine after the rebuilt, but we didnīt change the solenoids.
What could be the cause for that problem? Could it be a bad solenoid and is it possible to check / change them with the transmission in the car?
Thanks for help!
Old 10-30-2012, 07:46 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Have you checked for a blown fuse?
DOes the speedometer function correctly?
Old 11-03-2012, 04:53 PM
The fuses are good, the speedometer works. Any other suggestions?
4l60e problem 1990k1500 Transmission - Rearend 8 03-02-2011 08:58 AM
4L60E problem pjposton Introduce Yourself 2 08-06-2009 08:03 PM
4l60e Problem 84'Monte Transmission - Rearend 11 06-30-2009 09:17 PM
4l60e Problem hunterfreek1 Transmission - Rearend 2 04-18-2009 11:35 AM
4L60E problem torqueman Transmission - Rearend 12 12-16-2006 08:24 AM
