4l60e problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-11-2006, 05:24 PM
4l60e problems
i have a 1995 gmc 1/2 ton 4x4 the about 4 months ago my tranny let go it only had 1st and 2nd and rev. and i replaced it and about two weeks ago it let go again it only has 1st 2nd and rev. i took the pan of and theres no shavings at all in it and i was wounderin if anyone has had this problem
Old 05-11-2006, 09:16 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
what did you replace the original trans with? A fresh rebuild? Any warranty?
the 3-4 clutch pack in this tranny is a problem since the design was introduced in the 700r4 in 1982
Old 05-12-2006, 12:18 PM
i bought the tranny it has maybe 60,000 on it and cuz it doing the same thing as the one before it. Could it be electrial problems?? Or could it be a solenoid that could be screwing it up. cuz i tore the other one apart and it seamed to be fine the only thing i could see is the rubber o ring on the end of the solenoid was tore.
Old 05-12-2006, 08:10 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
electrical problems usually set a code or 2.
The shift solenoids are both energized for 1st gear. One sol turns off = 2nd gear. Both sol off = 3rd gear.
How experienced are you with automatics? Could you tell if the 3-4 clutch pack had too much clearance? If the 3-4 pack does not function , there is no 3rd or over drive.
Other items could be wrong too , creating the same problem in both trannys for different reasons.
I'm not much help , sorry
Old 05-12-2006, 10:14 PM
well thanks but i prolly have to replace it i gone one engine and two transsmisions sence last october i just thought maybe some one would know if there could be anything electrial that would cause it do do the same thing as the first on did
4L60E Shift Problems chianesi Transmission - Rearend 11 01-10-2006 04:16 PM
4L60E transmission problems BICHN69 Transmission - Rearend 6 03-26-2005 12:32 PM
4L60E transmission problems BICHN69 Engine 1 08-15-2004 12:23 AM
shift problems 4l60e justtwinz Transmission - Rearend 2 06-15-2004 09:06 PM
4L60E shift problems 68vortec Electrical 0 07-10-2003 12:10 PM
