4l60e probs - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-24-2005, 10:43 PM
4l60e probs
i have a 94 firebird that is pushing quite a bit of power more then likely close to 450 at the flywheel and the trans has a shift kit and just recently when i run it out it hits second and its like neutral till i let off and then its fine again... it used to spin the tires quite a bit when it hit second? the trans only have 55k on it so what has happened or what do i need to fix?
Old 06-25-2005, 10:11 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
you need to fix the problem with 2nd gear .
there are a few cuases for lost 2nd gear.
A broken band, broken band strut , burned up band , stripped teeth on the drive shell.
EDIT: I forgot , a damaged 1-2 accumilator will leak pressure
Old 06-25-2005, 10:27 PM
see i still have second gear its still there is just when i am on it hard it wont catch till i let off the gas but then its fine again. maybe this will help narrow it down
Old 06-26-2005, 01:45 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
does not change anything.
You need to check the items I listed
Old 06-26-2005, 04:56 PM
well do you have any idea what is most likely the problem or could it be any of those things. i guess more of what im asking is which one usually goes out first.
2005 4L60E tranny Crosley Transmission - Rearend 8 05-18-2008 01:51 PM
isolator valve, sleeve, regulator valve for 4l60e? mike 96 ws6 Transmission - Rearend 28 01-29-2006 11:16 AM
questions about 4l60e 85ta383 Transmission - Rearend 3 04-10-2005 08:27 AM
4L60E compatibility snimmo Transmission - Rearend 4 02-11-2005 05:18 PM
Clueless 4L60E question bluesman123 Transmission - Rearend 2 08-02-2004 09:59 AM
