4L60E pump problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-22-2007, 07:01 AM
4L60E pump problem
Hey guys burninrubber here again,got another stumper.
My 4l60e as some of you know has been rebuilt a few times. I am having a problom keeping the pump together, I have taken out 4 pumps and the transmission shop cant figure it out. I have checked my flywheel and it is fine but I replaced it any way. I checked my crank and it is running true also.
The pump only quits under normal driving say around 70-80 Klm an hour, the inside dogs that the torque converter slide onto break.Iwas running a 2200 stall and thats when this all started so Iam putting the 1850 stall back in.
Could it be the converter or should I be looking elsewere before I put this peice of junk back in for the 6th time.
Any help would be much appreciated
Old 10-22-2007, 05:56 PM
i would be inclined to think maybe threr is somethig wrong withthe verter
Old 10-23-2007, 01:01 PM
pump problem
Thanks performabuilt I agree and I have been saying all along and they finally gave me a different one.So I guess this weekend will be the test run .
If you remember we talked before I had a problem with third gear ring popping out,that turned out to be a bad drum.
4L60E shift/speedo problem when cold Blazer55 Transmission - Rearend 1 10-22-2006 06:41 PM
Forgot to prelube front pump! is it a problem? supercab78 Transmission - Rearend 2 07-02-2005 09:02 PM
Fuel Pump? Cam Problem? riesman20 Engine 24 05-06-2004 09:40 AM
Lean backfire Camaro76 Engine 5 04-15-2003 05:45 PM
Power Steering Pump Problem... IWasBlown Engine 1 04-07-2003 09:03 PM
