4L60E question - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-14-2008, 07:35 PM
Vortech 4.3's Avatar
jack of all trades
4L60E question
i think the bottom port is the out, and top is in, correct ?
trans cooler, ports on the side, 1 top, other bottom. does it matter what trans port goes to cooler port ?
fluid leaves the trans from the pump, correct ? when it returns to the trans, where does it go ?
thanx
Old 04-14-2008, 08:07 PM
Crosley's Avatar
Wiki Edits: 1659
thanx
yes... bottom fitting = out ....
either port on cooler is fine. Cooling system of trans is under pressure... there should be no check valve in this cooling system.
Fluid leaves trans out of the converter... returns from cooler to the lube circuit of trans.
Old 04-14-2008, 08:31 PM
Marcel
Last journal entry: Choo-choo town
trans. cooler hook ups /
I (IMO) would connect the bottom trans line to the bottom cooler line, that way the fluid from the trans. would keep the cooler full at all time before returns to the trans. The other way if the pressure every got low, it may drop through the cooler allowing air in the system, and not cooling the fluid. It also gives the fluid more time to cool.
I'm also the guy that likes putting a bolt up from the bottom with the nut on top. That way if the nut comes off, the bolt will drop out, and should be seen sooner. The other way, the nut falls off, and it wobbles around egg shaping the hole, if you don't catch it. (JMO)
Old 04-14-2008, 08:47 PM
jack of all trades
ok. the lube curcuit. does the cooled fluid augement the curcuit, or is the curcuit completely reliant on the cooler fluid ? or put another way. the cooler line gets pinched. assuming the trans is not hot, will it work fine (and no damage), until it overheats ?
what is the best cooler line size ? would putting larger make a good difference ? would putting smaller hurt anything ?(assuming the trans is not overheating)
thanx
Old 04-14-2008, 08:53 PM
jack of all trades
i agree
i disagree. i put the bolt in from the top, nut on bottom. if the nut falls off, there is still something there to, at least try, to hold whatever its in. if the bolt falls out there is nothing holding whatever. this can be correctly argued either way.
Old 04-14-2008, 10:07 PM
Crosley's Avatar
Wiki Edits: 1659
It is a pressure fed cooling system, not open to get air into it.
Old 04-14-2008, 10:09 PM
Crosley's Avatar
Wiki Edits: 1659
thanx
It feeds the lube circuit... cut off lube the trans burns up... same process on an engine , cut off lube,, the engine burns up.
Old 04-15-2008, 06:39 PM
jack of all trades
ok, thanx.
Old 04-15-2008, 08:09 PM
Crosley's Avatar
Wiki Edits: 1659
apologizes.... I did not answer the line size question.
Does your 4L60E have clip in lines or thread in?
Some early 4l60e units had 5/16" line with larger fittings than the regular 5/16 steel line you buy from a parts store.
5/16" line steel is fine. no smaller!
check your fittings for the design / size they are.
Old 04-15-2008, 08:29 PM
jack of all trades
thanx. i replaced the clip fittings with 5/16 fittings, and run all steel 5/16 hard line. to a large b&m cooler with a fan on it. and a temp gauge.
Question about vehical weight and engine question Thuggishruggish3000 Engine 12 03-24-2011 05:22 AM
383 stroker 73monte Engine 10 12-05-2009 08:02 PM
4l60e transmission question rodneydav123 Transmission - Rearend 6 03-08-2009 04:12 PM
4L60E shifter cable question garretthes Transmission - Rearend 1 10-31-2007 06:45 PM
nitrous 69BiRd Engine 2 11-28-2003 10:33 PM
