4l60e question - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-09-2009, 09:22 PM
94chevys10_zr2's Avatar
4l60e question
im going to a pick and pull placetomm, i need to know if all the 4x4 4l60e's are the same, like can i take a 4l60e from a new truck and put it in my s10, will everything line up bolt wise and are all the electrical connectors the same, or do i have to get it from another s10 zr2 truck thats the same year as mine which is a 94. all in all what vehicles can i pull a 4l60e from and have it bolt right up with no issuse other than putting it in and driving away. ps. my truck is a 94 s10 zr2 4.3 L
Old 07-09-2009, 09:27 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
1993 and 1994 4L60e of the 4x4 design will bolt right in and plug in corectly.
It must be off a V-8 or 4.3 V6 engine
In 1995 - 1996 , GM changed the Lockup strategy ( operation - control) on the torque converter
Old 07-09-2009, 09:29 PM
so i have to use a 4l60e off a 93 or 94 truck?
Old 07-10-2009, 07:04 PM
94 chevy s10 zr2 transmission match up
i have a 94 chevy s10 zr2 with the 4.3L vortec, i went to a pick and pull today and found some trucks and blazers, will the 4l60e out of a 93/94 blazer/ gmc jimmy work with my truck. and does anyone have any specs on my tranny. bolt patterens, i dont want to drive another 140 miles and bring back the wrong one, tell me what i need to look for
Old 07-10-2009, 07:36 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
as I posted in your other thread;
a 1993 -1994 4L60e trans of the 4x4 design will bolt into your vehicle and plug into the wire harness.
It must be off a V8 engine or the 4.3 V6 engine
Old 07-17-2009, 08:39 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
bump to the top..
I merged 2 more threads together here.
Trying to keep the same questions together.
383 stroker 73monte Engine 13 05-11-2016 11:17 AM
4l60e transmission question rodneydav123 Transmission - Rearend 6 03-08-2009 04:12 PM
4L60E question Vortech 4.3 Transmission - Rearend 9 04-15-2008 08:29 PM
4L60E shifter cable question garretthes Transmission - Rearend 1 10-31-2007 06:45 PM
nitrous 69BiRd Engine 2 11-28-2003 10:33 PM
