4l60e question - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-01-2011, 01:37 PM
chevrolet327's Avatar
second place is the first losr
Last journal entry: old stlyle holley polished valve cover
4l60e question
i have buy a 2001 1500 with 4l60e the guy have changed transmission and she do not run the transmission dont do nothing in any gear i dont see PRND321 in dash and the tranny look like to have too much oil 3-4 quart
Old 02-01-2011, 02:13 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Has any attempt been made to read the codes?
I would correct the ATF level. Then I would double check that the electrical connectors are installed together tight and that there are no obvious problems w/them, the range switch is also said to be prone to probs.
I seem to remember something related to the ignition switch having an effect on the trans, but I do not recall any details.
Old 02-03-2011, 11:09 AM
old yukon's Avatar
AS Cobolt327 suggested, scan it for codes.
I would also check electricals, fuses and the intrument cluster. The instrument clusters are common faults in those model GM's I asume you have a GM Tahoe, Sierra or simular to that. I had simular issues with the display.
4l60e question 94chevys10_zr2 Transmission - Rearend 5 07-17-2009 09:39 AM
4l60E EPC Question JSGAuto Transmission - Rearend 3 01-30-2009 06:45 PM
4L60E Question Hitman44 Transmission - Rearend 6 11-12-2008 06:16 PM
4L60E question Vortech 4.3 Transmission - Rearend 9 04-15-2008 09:29 PM
4L60E question 36scsc Transmission - Rearend 12 01-16-2005 09:05 AM
