Originally Posted by Jmark
The trans you bought is for a chevy engine, what engine is in your TA?
I was under the impression that all 4L60E trans had a removable bell housing, but that one does not. Waiting for Mr. Crosley to straighten out the cornfusion here.
Mark
Add-on info found online.
"The key distinction of the Later 4L60-E (1997-2006) from the Early 4L60-E (1992-1997) or 4L60 (1990-1992) or 700R4 (1982-1989) is the six-bolt "hex" rear output or tailhousing / adapter pattern. The previous versions featured a four-bolt square bolt pattern at the adapter or tailhousing. Additionally, the removeable bellhousing is also another distinguishing feature between the early and late 4L60E."
All 700 / 4L60 trannys are chevrolet V-8 bell housing pattern on the fixed bell tranny case, cept for the small case V-6 bell
jmark......... obviously you have learned something new about the 4l60E tranny.
Crosley do u think this trans mission can fit in my 1994 Trans AM?
Decotoxiver..... did you read my earlier comment in this thread on the 94 caprice tranny? The TA should have a torque arm from the diff up to a mount on the tranny tail housing
In the 1995 model year 4L60E the elctronics were changed for a PWM converter lock up system.
