Anbody ever use or know about this kit? It's from PACT(TransmissionCenter)
Looking for hiperf kit. PEACE OUT>Tony
√ #24. - - - Master 700-E Raptor Rebuild Kit (4L60E). This package deal comes with: an Alto master rebuild kit with an 8 clutch Red Eagle Power Pack and full thickness Kolene steels for the 3-4 clutch, "The Beast" reaction shell, pump bushing, case bushing, extra wide sun gear bushing, pump seal retainer, filter, heavy duty / high performance converter - #2 or #2L on the converter list, thrust washer kit, high performance Superior 2nd gear billet servo (not a Corvette servo), high performance Superior overdrive billet servo, oversize pressure boost valve, 29 element Borg Warner forward input sprag, 13 vane pump kit, performance 1-2 accumulator spring, special intermediate servo release check valve, high output pump slide spring, Raybestos Pro Series black Kevlar 2-4 band and the freight is included anywhere in the 48 United States. All of this can be yours for $904.00. Now you can tow 6,000 pounds in overdrive, try that with a stock 4L60E transmission. You can add or subtract from this package deal. Fits 1993-1996 4L60E transmissions. Add $54.00 for 1997 up with high energy and Red Eagle clutches. Spend at least $700.00 on this kit and you get free UPS.
