4l60e rebuild no overdrive or reverse - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-13-2014, 07:44 PM
I just rebuikt the 4l60e out of a 96 1500 and no reverse or overdrive. Im going to check out valve body i put 7 balls in 1 near accumulator n two incapsulated. All bolts were pulled off n put in cardboard template n put back in so they should be good but ill check. Im hoping the reverse booster piston has an issue but what about overdrive. It has 1-3 good and engine braking checked out so im hoping its just something in the valve body
Old 07-19-2014, 02:15 AM
Wow noone really
Old 07-19-2014, 08:28 AM
TexasT's Avatar
Did you ever wonder?
Last journal entry: A little follow up
Do you have enough fluid in it?
check the valve body gaskets for correct position on the case and/or vb side of the plate.
Did you air check the pistons when you were putting them together to verify operation?
Old 07-19-2014, 08:47 AM
Burnt out transmission tech.
Hmmmmm.
This was six days ago.
Surely you have discovered something by this time.
Old 07-19-2014, 09:23 AM
TexasT's Avatar
Not if he didn't take it apart.
OP, what have you tried?
Old 07-19-2014, 11:39 AM
Yes air checked i put all new clutches n seals fluids topped ran truck kept toppin off to make sure it is full
Old 07-19-2014, 12:19 PM
TexasT's Avatar
so, where are we at six days later?
Have you dropped the pan and checked out the check ball locations?
Have you put a gauge on it to see what you have for pressures in those and the other gears?
Do you have a scan tool to see if the trans is calling for fourth?
Old 07-19-2014, 12:21 PM
I have not checked any pressures or codes yet i am offshore working for three weeks now when i get back ill update
Old 07-19-2014, 12:52 PM
TexasT's Avatar
Well,at least you are working and will have money to throw at the problem.
Ya'll drillin, logging, shootin, fracin? or something entirely different offshore? I worked wireline for a few years. Best money I ever made.
Old 07-19-2014, 05:12 PM
Im a heli mech actually work onshore its just easier to say i work offshore
Old 09-11-2014, 03:34 PM
Got reverse now boost valve snap ring wasnt seated but still no overdrive
Old 09-12-2014, 09:02 PM
Any suggestions on overdrive??? I was going to get a scanner to check for codes but possibly the servo installation incorrect?? Also my 1-2 and 2-3 shifts are pretty firm i want to change up the accumulator spring
Old 09-17-2014, 09:10 AM
Any thoughts on this??? I was thinking about checking the servo ive read about some people needing to shim it. Its a HD servo kit. Also i have hard shifts from 1-2 n 2-3 i know where the 1-2 accumulator is i can mess with but what about 2-3?
Old 09-17-2014, 09:34 AM
TexasT's Avatar
I believe the 2-3 accumulator is integrated into the servo.
Make sure the computer is calling for overdrive. Then see about the electric servo that shifts it. Then see about the seals in the overdrive clutch apply piston.
Old 09-17-2014, 09:57 AM
I air tested everything before i put it back together but what are you calling the electric servo
4l60e slips in 2nd and no reverse after rebuild colby.k Transmission - Rearend 1 10-17-2013 08:48 AM
4L60E no reverse after rebuild stealth vn Transmission - Rearend 0 04-28-2011 06:54 AM
4l60e - No reverse after rebuild - Low line pressure? reddeth Transmission - Rearend 5 06-03-2009 09:12 AM
4L60E no reverse after rebuild! pauldotcom Transmission - Rearend 13 03-06-2009 02:03 PM
700r4 no overdrive reverse supercoop Transmission - Rearend 20 12-14-2008 11:16 AM
