Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 4L60e, to rebuild or not rebuild, that is the question ?
Old 12-13-2010, 06:16 PM
transbuilderguy transbuilderguy is offline
if you are wanting to learn the 4l60e is not the trans to learn with the hydraulics in the 60e are complicated you can put all the parts you want to in it and if the hydraulics are not sound it will fail. Something as simple as a #7 checkball leaking can cause a 3-4 failure everytime and you wouldt even know its leaking if you didnt have expereince to see it. If you wanna learn get a th400 and learn on that trans its simple drum to drum all planets are in the rear and the hydraulics are simple. I would hate to see you waste money and spend more than you would have if someone just did it for you. On the other side is it do-able yes as long as yu follow the ATSG to the T as far as inspection and listen to the guys on this site as far as setup then you can do it with basic mechanical knowledge. I am here to help make sure to ask alot of questions
