Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 4L60E rebuild--updates required?
Old 07-19-2012, 10:47 PM
pricesgarages's Avatar
pricesgarages pricesgarages is offline
sonaxx .490 oringed boost valve provides more line psi under heavy acceleration
sonnax tcc regulater valve will need a reamer to install it prevents tcc slip and dtc 1870 burn clutches
sonnax tcc apply valve goes in the pump
trans go seperator plate and trans go jr shift kit
corvette servo
The Following User Says Thank You to pricesgarages For This Useful Post:
abbazabba (07-25-2012)
