-   -   4L60E rebuild--updates required? (http://www.hotrodders.com/forum/4l60e-rebuild-updates-required-221907.html)
abbazabba 07-19-2012 07:59 PM
Working on a 1998 Chevy k1500 5.7 350. 4L60E trans. I have the ATSG Manual and the ATSG update. Can any of you experienced transmission builders confirm what updates must be done. Most of the updates in the manual are for older model years and I just want to make sure I have done every last one that is needed.
Also does anyone have feedback from the Monster Transmission rebuild kits?
Thank you in advance.
pricesgarages 07-19-2012 09:47 PM
sonaxx .490 oringed boost valve provides more line psi under heavy acceleration
sonnax tcc regulater valve will need a reamer to install it prevents tcc slip and dtc 1870 burn clutches
sonnax tcc apply valve goes in the pump
trans go seperator plate and trans go jr shift kit
corvette servo
abbazabba 07-21-2012 01:30 PM
Thanks Josh.
pricesgarages 07-24-2012 10:04 PM
i like sonnax parts they give great drivability and cure common problems with the transmissions
abbazabba 07-25-2012 01:24 PM
Josh,
Who is the best distributor of sonnax parts? I have looked around online but whats your opinion?
pricesgarages 07-25-2012 10:08 PM
were are u located
abbazabba 07-26-2012 09:15 AM
Colorado Springs, CO
pricesgarages 07-26-2012 10:45 PM
transmission parts usa is in fla it takes 3 days to wva they have ok deals but sells sonnax get the part numbers find a local tranny shop to order them from transtar
