4L60E rebuild--updates required? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-19-2012, 08:59 PM
Working on a 1998 Chevy k1500 5.7 350. 4L60E trans. I have the ATSG Manual and the ATSG update. Can any of you experienced transmission builders confirm what updates must be done. Most of the updates in the manual are for older model years and I just want to make sure I have done every last one that is needed.
Also does anyone have feedback from the Monster Transmission rebuild kits?
Thank you in advance.
Old 07-19-2012, 10:47 PM
pricesgarages's Avatar
sonaxx .490 oringed boost valve provides more line psi under heavy acceleration
sonnax tcc regulater valve will need a reamer to install it prevents tcc slip and dtc 1870 burn clutches
sonnax tcc apply valve goes in the pump
trans go seperator plate and trans go jr shift kit
corvette servo
The Following User Says Thank You to pricesgarages For This Useful Post:
abbazabba (07-25-2012)
Old 07-21-2012, 02:30 PM
Thanks Josh.
Old 07-24-2012, 11:04 PM
i like sonnax parts they give great drivability and cure common problems with the transmissions
Old 07-25-2012, 02:24 PM
Josh,
Who is the best distributor of sonnax parts? I have looked around online but whats your opinion?
Old 07-25-2012, 11:08 PM
were are u located
Old 07-26-2012, 10:15 AM
Colorado Springs, CO
Old 07-26-2012, 11:45 PM
transmission parts usa is in fla it takes 3 days to wva they have ok deals but sells sonnax get the part numbers find a local tranny shop to order them from transtar
abbazabba (07-27-2012)
1998, 4l60, chevy, transmission, transmission rebuild
4L60e, to rebuild or not rebuild, that is the question ? old yukon Transmission - Rearend 31 04-07-2011 01:25 PM
What for 4L60E rebuild? bodie filyaw Transmission - Rearend 1 01-29-2011 08:07 AM
4l60e Rebuild fschevy Transmission - Rearend 8 12-14-2010 08:44 PM
4l60e trans rebuild Blackhauk90 Transmission - Rearend 3 12-14-2007 01:11 PM
4L60E Rebuild mitchc Transmission - Rearend 2 12-19-2006 08:50 PM
