4L60E reverse gone - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-03-2010, 03:11 AM
4L60E reverse gone
I have a 94 chevy 1500 Z71 with a 4L60E. All my forward gears work fine.Reverse on the other hand is gone. I put it in reverse and all that happens is the engine revs and I have no movement. Occasionally I will get a little movement at high end RPMs. Anybody have any idea what could be the problem.
Old 07-03-2010, 10:29 AM
Crosley's Avatar
Wiki Edits: 1659
Mileage on the trans?
You have 3 shifts for sure? 1 - 2 shift, 2 -3 shift, then shift to 4th gear?
Drive the vehicle to 20-25 mph (max) in manual 2 shifter position.. pull shifter to manual "1" , there should be noticeable engine braking when shifted to "1" at speed.
If engine brake happens, then the problem is the reverse input clutch pack.
Old 07-03-2010, 11:26 AM
That just sounds like your clutch pack is gone
1997 Suburban 4x4, 4l60e no reverse, imagine that. t00lmanii Transmission - Rearend 16 11-02-2009 07:48 AM
4l60e - No reverse after rebuild - Low line pressure? reddeth Transmission - Rearend 5 06-03-2009 09:12 AM
4l60E Slow Reverse jadejoky28 Transmission - Rearend 4 05-21-2009 10:41 AM
4L60E Weak Reverse rsruss800 Transmission - Rearend 3 03-23-2008 05:00 PM
