Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 4L60E Reverse Only
Old 08-10-2011, 06:22 AM
Crosley's Avatar
Crosley Crosley is offline
Wiki Edits: 1659
interesting problem,
Any idea the mileage on the trans?
Have you moved the shifter all the way to manual 1 and still no movement forward?
This trans does not require voltage power to activate a solenoid for forward gears to engage.
