4L60e Servo Cover Seal - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-06-2009, 10:42 AM
123pugsy's Avatar
"Thread Cop"
Last wiki edit: Metal shaping
Last journal entry: SEAM SEALER
Wiki Edits: 29
I am wondering what would cause the servo cover seal to blow out on a freshly built 1997 4l60e tranny.
It was working fine when installed and then blew out 2 days later.
Thanks,
Pugsy
Old 02-06-2009, 07:51 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
I am guessing here; the cover snap ring blew out too?
Often the cause is the snap ring was not seated properly by the builder OR there was dirt - debris or corrosion in the snap ring groove that did not allow the snap ring to seat properly.
I have also seen the aluminum edge of the servo area break away and allow the cover to come loose.
Old 02-07-2009, 04:46 AM
123pugsy's Avatar
"Thread Cop"
Wiki Edits: 29
So, do you think RTV should be used rather than assembly lube on initial install?
I was told the snap ring was still in place.
Old 02-07-2009, 07:32 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Never use RTV there, it is useless with the pressure on the servo cover.
I have never seen a snap ring in place when a cover blows off the 2-4 servo cover. I'd replace the cover and snap ring.
Although..... TransGo used to offer in his kits a thinner snap ring to allow the servo cover to move out slightly to increase band clearance. In my opinion That was a bad Idea from TransGo and that perhaps is the problem here?
Old 02-07-2009, 04:16 PM
123pugsy's Avatar
"Thread Cop"
Wiki Edits: 29
Thanks Crosley.
I'm gonna go check it out tommorow.
Pugsy
Old 02-08-2009, 08:23 PM
123pugsy's Avatar
"Thread Cop"
Wiki Edits: 29
The top tranny line had one of those interesting slide in with a wiggly clip thingy. It was loose and leaking down making it appear that it was coming from the servo seal.
All is good.
Zoop Seal coating for polished aluminum, RESULTS!!!!!!! fordSR Engine 15 02-05-2010 12:04 PM
4L60E tail housing seal leak bluesman123 Transmission - Rearend 13 01-31-2005 10:54 PM
Front Seal 4L60E edge Transmission - Rearend 4 01-31-2005 08:17 AM
Front oil pan seal on Small Block Chevys gearhead77 Engine 19 09-26-2004 08:58 PM
98 4L60E billet servo blown68ssrs Transmission - Rearend 1 05-30-2004 04:46 PM
