4L60e Servo springs - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-29-2009, 09:04 AM
123pugsy's Avatar
Last wiki edit: Metal shaping
Wiki Edits: 29
4L60e Servo springs
I got a 4L60e in Monday and found 3 servo cushion springs and a shim wire thingy.
Is this stock or some kind of home made shift kit?
Its a 2000 S-10 2.2 liter.
Thanks,
Pugsy
Name:	IMG_0028 (Small).jpg
Old 07-29-2009, 11:45 AM
4L60e Servo springs
looks right to me , heated spring with burnt paint is a way of shade tree shift kit .i've seen it .
Old 07-29-2009, 03:20 PM
tnsmith10's Avatar
when will it rain???
Thanks,
Pugsy
if i remember right, the yellow is for corvette, the blue comes in the transgo jr shift kit, and the plain i believe is a stock oem cushion spring. as far as the shim wire thingy well, thats some creativity, from what i can tell. lol
whats this trans doing that would require such a setup? ive seen 2 springs in there, but not 3.
Old 07-29-2009, 06:30 PM
123pugsy's Avatar
Wiki Edits: 29
Its a 4 banger S-10, and the customer is complaining of vibrations when it shifts.
All clutch packs, seals all were in good shape.
Could this servo spring business cause this?
Old 07-29-2009, 06:38 PM
what shape was the governor in ?
Old 07-29-2009, 07:49 PM
Crosley's Avatar
Wiki Edits: 1659
those are transGo springs from the orange box shift kit.
Large spring is OEM... the inner 2 springs are TransGo. The wound up wire is TransGo.. I never install the wire.
Burntolds... there is no governor in a 4L60e trans.. it is electronic controlled - shifted
Old 07-29-2009, 07:52 PM
Crosley's Avatar
Wiki Edits: 1659
vibrations when trans shifts to what gear? All ?
If the complaint is shift chatter into 3rd gear...
clamp input shaft in a vise... twist the aluminum drum to see if the shaft is loose in the splines. Loose splines will cause shift chatter. in 3rd gear mostly
Old 07-29-2009, 07:53 PM
yes your right on that , too many things on mind , i screwed up . i admit it , most don't
Old 07-29-2009, 07:56 PM
tnsmith10's Avatar
did you drive this truck and verify the vibration during the shifts? if so, does it do it on every shift or just certain gears? maybe when t.c.c. comes in? is the truck a long bed or extended cab? does the driveshaft have a carrier bearing?
was there any trouble codes in the trans or engine?
thx for the clarification there crosley, i dont see enough to remember which springs, what color. thats why i mark anything questionable on dissassembly so i get it right on assembly.
Old 07-30-2009, 08:17 AM
123pugsy's Avatar
Wiki Edits: 29
Thanks Guys.
The customer says that the truck runs smooth at higher rpms until the shift and then vibrates after the shift has occurred and the RPM's have dropped.
Basically happening all the time.
I did not drive the truck myself.
The tranny was dropped off in a box disassembled.
He said its the 2 piece drive shaft with the hanger bearing.
It was rebuilt 3 years ago and this vibration has been there since.
No codes. O2 sensor only.
Old 07-30-2009, 08:36 AM
tnsmith10's Avatar
if its been there since the rebuild, id check conveter and the driveshaft. either the converter has a balance issue, or the driveshaft is out of time, or bad carrier bearing. other things to look for is bad engine and trans mounts, a poor running engine, when rpms dropping on each shift, if the engine is down on power, i can see it causing a vibration from lugging being underpowered. gl
Question with Valve Springs Diameter Houman SS '70 Engine 6 03-17-2008 11:31 AM
Broken valve spring(s)...? Bumpstick Engine 5 06-06-2005 07:33 AM
1967 Chevelle Springs? sicksixseven Suspension - Brakes - Steering 2 03-25-2005 03:11 AM
new pushrods and springs? underdog305 Engine 2 02-18-2005 08:25 AM
Diffrent Springs? strikingthematch Engine 3 12-09-2004 09:12 PM
