4L60E shift kit-cpu reprogram? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-22-2012, 10:51 AM
1998 Chevy k1500 5.7 350 4l60e trans. I was told that after 97 in these transmissions.. if you install a shift kit the computer must be reprogrammed or flashed to be able to control the trans. Is there any truth to this?
Old 07-22-2012, 06:05 PM
Crosley's Avatar
Wiki Edits: 1659
nope
The Following User Says Thank You to Crosley For This Useful Post:
abbazabba (07-25-2012)
Old 07-24-2012, 10:02 PM
joshp83's Avatar
owner of Prices Garage
agreed with Crosley u can firm up shifts threw computer tuners but not a nessasity
The Following User Says Thank You to joshp83 For This Useful Post:
4l60e, chevy, computer, shift kit, transmission
4L60E Shift kit. GMCTRUCKS Transmission - Rearend 8 05-20-2012 03:22 PM
TransGo reprogram kit PontiacFighter Transmission - Rearend 4 04-22-2012 03:15 PM
TH350 reprogram kit questions lngliv3 Transmission - Rearend 2 11-07-2009 10:39 AM
4L60e 2-3 shift slow after installing kit ckucia Transmission - Rearend 3 09-01-2009 11:09 AM
