Demon carburetor Get parts for cheap, all for a good cause.
Parts auctions to protect free speech online.
Click here for details.
Parts currently up for auction: Rat rod chassis parts, Demon carburetor, aluminum Hemi head, 1947 Chevy engine + suspension + parts, '30-'31 Ford headlights, '33-'34 Ford window regulator, "Power Rods" billet air cleaner top.
Mopar performance heads
Hotrodders Bulletin Board > Tech Help > Transmission - Rearend
  #1
Old 08-07-2005, 09:46 AM
silm man silm man is offline
New Member
4l60e shift point question
Does tire size and gear ratio change make a big differences in shift point on a 4l60e transmission . Example stock tire 28 inches 3.42 gear ratio , change to 26 inches with 3.73 gears ratio . Will the 26 inches and 3.73 gears ratio change cause the transmission to shift fast and the rpm to be higher . Next question how do you adjust the transmission shift point's on a 4l60e transmission after a gear ratio transmission change.
Old 08-08-2005, 08:30 PM
Crosley's Avatar
Crosley Crosley is offline
Moderator guy
 Crosley's barnstar
re: 4l60e shift point question
gear ratio & tire diameters changes will cause the shift points to change. The PCM shifts the tranny at certain programed settings & input from various sensors on the vehicle. If you install larger tires the PCM will think the vehicle is traveling slower, when it is at the same speed that the OE tires produced.
Custom programming or changing the parameters in the PCM with availible softeware for that purpose.
Be kind to your children... some day they may be decide what nursing home to put you in
Old 02-19-2006, 03:23 AM
chico1 chico1 is offline
yes you will have to change the program the ecm came go to your local gm dealer and ask them to reprogram the pcm it takes about five to ten minutes find a cool shop and ask them to help you out should do it for free if not some dealers charge 1 hour labor me i dso it cause i like to do it drive up to santa barbara ask for chico @ hughes pontiac gmc volvo you need a tech2 to do this after market scanners do not have the capability good luck
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "4l60e shift point question"
shift problems 4l60e justtwinz Transmission - Rearend 2 06-15-2004 08:06 PM
98 4L60E billet servo blown68ssrs Transmission - Rearend 1 05-30-2004 04:46 PM
4L60E Cooling Question bluesman123 Transmission - Rearend 4 03-01-2004 10:11 AM
1984 700R4 B&M Shift kit question Russell52 Transmission - Rearend 4 02-25-2004 09:45 PM
Hotrodders Guidelines -- READ ME Jon Hotrodders' Lounge 0 06-14-2003 05:08 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2008. All Rights Reserved.
