4L60E Shift problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-26-2008, 06:41 PM
Freshly rebuilt tranny worked great for 6 months behind stock 5.7L chevy TBI(1995 Silverado 1500). Engine swap to BBC 540 (carburated); tranny wasnt ever removed. INstalled factory TPS switch to carb linkage and is sending / receiving proper signal. Speedo works. What would cause the vehicle to start off in 3rd gear and can manually shift down to 2nd and back to 3rd. No first gear, no OD. No prior problems with the tranny prior to engine swap; again the tranny was a fresh rebuild 6 months prior. What else tells the tranny to shift besides the TPS and Speedo sensor?
Frustrated and going no where; Brain
Old 08-26-2008, 06:56 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Sounds like the 4l60E is not getting any power feed (voltage)... default gear is 3rd in that trans when there is no connection.
Old 08-27-2008, 04:20 AM
Sounds good BUT what wire gives it power? I haven't disconnected anything from the tranny. There is a fuse for the tranny but it's not blown.
Old 08-28-2008, 08:39 AM
can any body tell me were does a 4l60e get its 12-volts from . i replaced the motor in my 95 chevy 1500 with a carbed bbc and now the tranny only has 3rd. some people have said that i have lost voltage to tranny. all the fuses are good . please help............
Old 08-28-2008, 06:46 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
the voltage comes down through the wire harness.
You may have a blown fuse , pinched the wire harness during engine swap , cut a wire , a bad ignition switch.
Default gear on this trans is 3rd gear. Default happens when there is no power & communication to the trans from the computer. This should set trouble codes immediately
If you are getting this problem , is the check engine trouble light on?
Has the vehicle computer been scanned?
GM 4L60E Problems GMkid43 Transmission - Rearend 15 08-25-2008 08:31 AM
s10 1995 2.2 2wd shift problems Showmehow Transmission - Rearend 7 01-25-2008 07:57 AM
borgwarner down shift problems rockandroller1991 Transmission - Rearend 7 02-16-2007 11:27 AM
shift problems 4l60e justtwinz Transmission - Rearend 2 06-15-2004 08:06 PM
Tranny shift problems. chevcamz28newbie Transmission - Rearend 6 08-09-2003 05:52 PM
