4L60E shift problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-10-2003, 11:10 AM
Help! Installed a 99 5.7 vortec with a 4L60E in a 68 Chev PU. I used the original harness, had Fastchip reflash the VCM, and changed the trans. tail shaft.(originally was 4x4). I have everything working, except it shifts to OD by 20MPH, then drops to 3rd and stays. Electronic speedo is right, so I assume VSS is correct. Suspect input signal from TCCM(that I don't have), that inputs to c4-23 on the VCM, but don't know. Any ideas? Thanks
