Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 4L60E Shift Problems
Old 01-09-2006, 01:50 PM
sbchevfreak's Avatar
sbchevfreak sbchevfreak is offline
Licenced Automotive Technician
Originally Posted by chianesi
I took the blazer out for another test run and I paid closer attention to the shift into second, it shifted smooth but still didnt shift into third. I slowed back down allowing it to downshift back into first and this time instead of creeping into a shift a gave it the gas and at the point where it should have shifted into third it almost felt as if it fell into neutral and the RPM's shot up to around 5k.
Originally Posted by Crosley
IF 1st and 2nd gears are operating , NO 3rd or 4th gears would indicate the 3-4 clutch pack is the problem.
The 3-4 clutch pack in this tranny has been a weak point since the tranny was introduced in the 1980's.
You have not indicated a mileage figure on the vehicle?
I think your answer has been found already.
