4L60E Slipping - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-16-2008, 01:42 PM
bluesman123's Avatar
4L60E Slipping
Looks like it may be time to replace the tranny in my V8 conversion Sonoma!
I let the fluid get about a quart low and that seems to have cooked it. Anyway, it is slipping on the 3-4 shift pretty badly. I am pretty clueless about trannys (among MANY other things! Just ask my kids!!) and would really appreciate some help with this...
1. Could anything else be causing this slipping? When I gas it at maybe 65 mph or so it feels like the clutch is slipping on a stick shift car.
2. I had a Hypertech tune on the truck for 3-4 years, including the firmer shifting option. I never really noticed much difference, but could this have hurt it?
3. The tranny in question is behind a 1998 5.7 litre out of a Sierra. Would it make any sense at all to replace it with either an R4 or something else? The truck is pretty much my daily driver (and maybe a little bit of a sleeper street thug) .
4. I have to keep this smog legal in California, but I am guessing they don't care about which tranny you have.
Thanks for your advice!
Dave
Old 07-16-2008, 02:18 PM
Last journal entry: T'Bird projectr
I was quoted 4-500 dollars to freshen up the '93 4L60E behind the 5.7 TBI I'm putting in my Diamond T, which seems reasonable to me. That's with me doing the R&R of course, but it seems cheaper than replacing a 4L60 with an unknown 7004. That, and your truck already is set up for the electronics, so why go backwards?
Old 07-16-2008, 02:57 PM
Wow! That's a good price, Brian. I've been quoted $1500 with me doing the R&R, but this is a pretty expensive place to run a shop (shop rates around here run $125-$200 per hour). Is that for a 60E or an R4? I thought '93 GMs were still using the R4s? When I looked online for rebuilds, the R4s are Lots cheaper than the 60Es...I guess because of the extra hassle of the electronics.
I guess part of my question is wondering if there is something stronger or more reliable than a 60E?
Dave
Old 07-16-2008, 06:48 PM
Yikes, that's higher than here. I'll admit I know the guy who does my trans work, so it may be a little less than the going rate. He did the AOD in my '59 'Bird when I fried it (TV cable fitting broke) for 300, and the 400Turbo for my 472 Caddy, for 500. Yes, it's a 4L60E, from a '93 Chev C10 van. It shifts fine, for now, but I thought it'd be a good idea to go thru it before it gets installed.
Old 07-17-2008, 12:40 AM
C-10's Avatar
Revolution Calling
Last journal entry: Poverty caps live on.
Dave
The hard parts that are responsible for the problem you are having are the same in either the 'E' or the R4. This is a well known failure in these transmissions. The parts to fix this shortcoming is readily available.
Look for a Raybestos Z-pak for the 3-4 clutch.
Use a Superior billet 2nd and 4th servo.
Use at least a .471 boost valve.
Use a WIDE (2 3/8") Carbon 2-4 band.
Consider a 13 vane pump also.
Combine this with a TransGo 700-JR recalibration kit and you'll have a much better trans. There is a difference between a firm shift and more holding power as far as durability goes.
Old 07-17-2008, 10:37 AM
Wow! Thanks C-10! That's just what I am looking for. My neighbor is certified to work on these things (right now he is a body man for a custom rod builder) so I am hoping he can help me do this myself. Your parts list is a terrific help.
Love this site!
Dave
Old 07-17-2008, 07:33 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
couple of items;
the 4l60E boost valve is a one piece - dual zone item. Which valve land would he measure for .471 size?
IF you use the wide 2-3/8 band.. make sure the drum area the band applies on is flat. Often these drums are warped and need a new replacement drum.
Old 07-18-2008, 12:47 AM
C-10's Avatar
Revolution Calling
Hi Crosley.
This one is a sonnax piece. It's a .490" (arrow) #77898E-K. It shouldn't be used on the late design pump. (2nd pic)
OEM's are either a .420 & .470 (not .471 ) I digress. I was .001 off.
Bluesman, maybe your trans already has a 13 vane pump, which is good.
ID:	31282   Click image for larger version
Old 07-18-2008, 12:52 AM
SSedan64's Avatar
Most HP Pro builders don't like the Carbon/Kevlar bands. They use the Alto Red Eagle wide bands. I think the 4L60E comes with a 13 vane pump. If you're going to use the larger billet servos I'd recommend the .500 TV Boost & .300 Low/Reverse Boost valves.
Old 07-18-2008, 07:14 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Originally Posted by C-10
Hi Crosley.
If a person chucks the early boost design sleeve in a lathe.. slight trimming here & there.. it fits the latest design stator.
Old 07-18-2008, 12:21 PM
C-10's Avatar
Revolution Calling
I will make a note of that. Thanks for the hint! Learn something new everyday.
4l60e Trans. GMCTRUCKS Transmission - Rearend 11 10-21-2007 02:39 PM
Tranny Slipping djg5211 Transmission - Rearend 11 06-30-2007 01:13 PM
4L60E rebuild kit ????'s Turbonoma Transmission - Rearend 0 04-14-2007 01:10 PM
4L60E 4x4 tarmon8r Transmission - Rearend 0 03-10-2006 08:47 PM
TH 350 Slipping Houman SS '70 Transmission - Rearend 10 12-23-2005 08:43 AM
