-   -   4L60E slipping in 1st low rpm 2nd 3rd OD and rev. fine (http://www.hotrodders.com/forum/4l60e-slipping-1st-low-rpm-2nd-3rd-od-rev-fine-219632.html)
jimhcom 05-20-2012 04:44 PM
I have just purchased 97 vette with a 4L60E that has just began slipping and grabbing at low rpm (almost like low fluid level) from a stop or when rolling 1 to 2 mph.
All other gears work fine and 1st seems OK at higher rpm. Also takes off fine in 2nd.
Any ideas?
pricesgarages 05-21-2012 12:05 AM
sounds internal the rear sprag probly is bad
jimhcom 05-21-2012 10:13 AM
Would that not affect reverse also? I do not have any problem in reverse.
Crosley 05-21-2012 11:02 AM
no, the design of the trans, that roller clutch 'holds' in first gear, free wheels in reverse.
Does this trans "slip" in manual first gear from a full stop take off?
