4L60E slipping in 1st low rpm 2nd 3rd OD and rev. fine - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-20-2012, 04:44 PM
I have just purchased 97 vette with a 4L60E that has just began slipping and grabbing at low rpm (almost like low fluid level) from a stop or when rolling 1 to 2 mph.
All other gears work fine and 1st seems OK at higher rpm. Also takes off fine in 2nd.
Any ideas?
Old 05-21-2012, 12:05 AM
pricesgarages's Avatar
sounds internal the rear sprag probly is bad
Old 05-21-2012, 10:13 AM
Would that not affect reverse also? I do not have any problem in reverse.
Old 05-21-2012, 11:02 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
no, the design of the trans, that roller clutch 'holds' in first gear, free wheels in reverse.
Does this trans "slip" in manual first gear from a full stop take off?
82 elcamino slips when maually put in 1st, 2nd, or drive but takes off fine from OD sanawa Transmission - Rearend 0 01-24-2012 02:36 PM
th350 slipping 2nd and 3rd lumberjacknooj Transmission - Rearend 6 09-26-2007 10:07 PM
4L60E whining in 2nd 3rd and OD but not 1st vtf_thor Transmission - Rearend 1 08-17-2007 09:15 PM
700r4 shift 2nd-3rd slip/rev 123pugsy Transmission - Rearend 2 04-25-2006 09:19 PM
