Sorry for the pause in between post, i still have flu and even typing is strenuous.
I could only check pressure in P R N @ "the tap is above shifter and it won't let it past @" i didn't road test it thinking i might try to shift to 3rd and break fitting off in case.I'm getting a 90 elbow fitting soon as I feel good enough.....
P110 min 190 max R 130 min 200 max N 110 min 180-190 max @110 min 200 max
When checking pressures on road test can i leave it in @, or will i need to do each manually? I loaned my ATSG book out so i no longer have a reference for pressures.Any and all help is appreciated, thanks for your time..
