4l60e slipping no reverse - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-16-2011, 10:26 PM
i have a 1996 blazer that is not operating right.when engine running the trans has to be put in low and acts like the brakes are on.once moving the trans seems to go to neutral and stops pulling, and there is no reverse it seems to be in neutral . anyone have this problem and can you tell me what you did to fix it.
Old 08-17-2011, 02:27 PM
jmaine83's Avatar
i had 87 blazer with a lil of the same problems change filter problem fix try you never know
Old 08-18-2011, 02:58 PM
I doubt seriously that changing the fluid is going to magically fix the problems, but it never hurts to be optimistic.
Dropping the pan will at least allow you to see how much metal, clutch material, bearing material, and/or thrust washer material is in the pan. Once you get the filter out, go ahead and cut it open and look inside.
I'm going to go out on a limb and say that you need a trans rebuild, or another transmission to replace the one you have.
Sometimes a broken sunshell will cause a loss of reverse, 2nd & 4th. So, essentially you would only have 1st & 3rd. So sunshell could be a possible culprit. Depending on mileage on the trans, it may also have worn out 3-4 clutches so it would be slipping when it goes into 3rd. Worn 3-4 clutches are the most common cause of failure in these transmissions. Let us know how it turns out.
4L60e slipping in 2-4 elwrencho Transmission - Rearend 7 12-01-2009 07:09 PM
4l60e slipping in reverse tabascojohn Transmission - Rearend 3 09-15-2009 06:57 AM
4l60E slipping in OD ratitak Transmission - Rearend 10 04-02-2009 10:52 PM
4L60E Slipping bluesman123 Transmission - Rearend 10 07-18-2008 11:21 AM
Slipping TH-350 with no reverse disaster fiscus Transmission - Rearend 4 07-12-2006 10:08 AM
