4l60E slipping in OD - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-28-2009, 02:18 PM
I have a 99 camaro with a 4L60 and is slipping at highway speeds under light ecceleration, until you let off and then eccelerate hard, after that it wont slip for a while. It never slips under hard ecceleration. does anybody have any idea what might be going on?
Old 03-30-2009, 02:53 PM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Crosley's Avatar
Crosley Crosley is offline
Crosley's barnstar Last wiki edit: Will a 89 gmc jimmy 4x4 700r4 transmission fit a 96 blazer
Wiki Edits: 105
Crosley's Photo Album
Crosley's Project Journal
could be many problems:
Too much band clearance,
accumilator bore damaged, piston pin hole worn out,
Cut lip seals,
mis assembled 2-4 servo pistons,
low pressure in OD, worn boost valve circuit
solenoid is weak , does not hold pressure for shift valve to O-drive
Old 03-30-2009, 06:38 PM
LEE EYES's Avatar
Last journal entry: TBI experiment.
what are you feeling? flare? lost speed? is it while the tcc is engaged?
Old 04-01-2009, 05:44 PM
Not sure what tcc means, but not really a loss of speed, more of an increase of rpm, but os soon as i let off of the gas and get back into it hard it does fine, and i can continue at highway speed and and it wont slip for a while until i start to play with the accellerator again by lightly accelerating and letting off. mind you this happins between 60 and 75 mph. will just cruzing.
Old 04-01-2009, 06:55 PM
LEE EYES's Avatar
tcc stands for torque converter clutch. depending on throtle position, you may be experiencing the tcc disengaging. but assuming that you have owned this vehicle for a while, this is a new condition. best guess at this time would be a tcc issue. mil on?
Old 04-01-2009, 06:58 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
LEE EYES:
it is best to post the response in English , not the letters for parts and stuff in the transmission. These guys for the most part do not know what you mean.
Old 04-01-2009, 07:05 PM
LEE EYES's Avatar
sorry... i forget sometimes. mil is the check engine light. is it on?
Old 04-02-2009, 10:26 AM
No i have not had the light come on yet, I had thought that these trans no longer had lockup converters, but if they do that makes a lot of sense, although when this condition happens the rpm's have reached as high as 4500 which led me to believe that it was some sort of clutch slippage.
Old 04-02-2009, 12:41 PM
LEE EYES's Avatar
yeah. torque converter clutch will only change a few hundred rpm... sounds like a pressure or seal issue. check tranny fluid?
Old 04-02-2009, 04:37 PM
Thanks, the guys at aamco said about the same thing after i had taken him for a drive to replicate the problem, they had it for two days and could not repliacate it themselves , I appreciate all the input, I am fairly good with mechanicals, and fuel injection, but when it comes to automatics i get a little lost. but again thanks so much.
Old 04-02-2009, 10:52 PM
LEE EYES's Avatar
i understand. i still have trouble, even after two years of training. there is always room to expand your knowlage base!
4L60E no OD??? Screech Transmission - Rearend 0 03-11-2009 10:22 PM
4L60E Slipping bluesman123 Transmission - Rearend 10 07-18-2008 11:21 AM
4L60E whining in 2nd 3rd and OD but not 1st vtf_thor Transmission - Rearend 1 08-17-2007 09:15 PM
4L60E turns to slush in od desotot Transmission - Rearend 2 07-22-2007 11:05 PM
AOD into mustang Stangman196700 Transmission - Rearend 3 12-16-2004 08:51 PM
