Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 4l60e sounds like I throw into park only at a slow roll
Old 03-18-2013, 04:07 PM
pilona42 pilona42 is offline
ok, so I got some fluid back in her and drove around a little. It still does it when I start out in second as well. Before I reistalled the pan I looked over the valve body again. I noticed somthing about that loose shift actuator that I had discovered previously. The rod that it controls doesnt seem to have any spring to it. Im not very familier with trannies but this did not seem right as all the other rods in the valve body have a sping action to retract it to a specific location. Is this somthing I should be concerned about?
