-   -   4l60e sounds like I throw into park only at a slow roll (http://www.hotrodders.com/forum/4l60e-sounds-like-i-throw-into-park-only-slow-roll-230854.html)
pilona42 03-17-2013 07:19 PM
Im hoping you fellow car guys can help me out on this one. I have a 97 chevy 1500 4x4 with a 4l60e tranny. I am experiencing a horrible clicking sound only at slow speeds and is in sync with engine rpm's. It sounds like I tried to throw it into park from a roll. Once I gain some speed it will go away. I can give it unlimited power with the brakes on in gear but at soon as the wheels start to move the sound reers its ugly face. I pulled the pan and everything looks fine. One of the shift solinoids seems a litte loose but it is cliped in securiy. Does anyone have any ideas. This is my only vehicle and I need to find the problem before a catostrophic falirure happens.
delawarebill 03-18-2013 07:50 AM
clicking ???
i'd jack it up and put on stands and try again.. u joint?? something in brakes...???
pilona42 03-18-2013 12:29 PM
I know its not the brakes because the clicking sound goes with the rpm's of the motor and not the wheel speed. Im gonna put the pan on and put some fluid in and see what happens.
Hogg 03-18-2013 12:51 PM
Place your shift selector in 2nd gear, then drive around and see if the noise is the same. You will start from a dead stop in 2nd gear. It will stay in 2nd gear as long as you keeo the throttle angle under 87.5%. If you go ver 87.5% while your speed is under 29mph, but once your speed is over 29mph the trans will stay in 2nd gear even at WOT all the way up to the stock 5600rpm rev limiter.
Your 97 could either have the 2 or 3 piece 4l60e. My 1997 rcsb 2wd Vortec 350 had the 2 piece originally. I am now running a 1999 3 pice unit.
2 piece-main body/integral bellhousing, tailstock- conventional bellhousing sheetmetal inspection cover
3 piece-bolt on bellhousing, main body, tailstock Has a 360 cast bellhousing
Some late 1997 trucks have the 3 piece 4l60e.
peace
Hog
pilona42 03-18-2013 12:56 PM
Thanks Hogg! I will try starting out in 2nd and post the results. Hopefully by tonight!
rick 427 03-18-2013 02:47 PM
Drive it easy...I'm thinking you may have a broken low planetary ring gear.
pilona42 03-18-2013 05:07 PM
ok, so I got some fluid back in her and drove around a little. It still does it when I start out in second as well. Before I reistalled the pan I looked over the valve body again. I noticed somthing about that loose shift actuator that I had discovered previously. The rod that it controls doesnt seem to have any spring to it. Im not very familier with trannies but this did not seem right as all the other rods in the valve body have a sping action to retract it to a specific location. Is this somthing I should be concerned about?
