Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 4l60e started slipping
Old 07-28-2012, 10:46 PM
Crosley's Avatar
Crosley Crosley is offline
Global Moderator
Wiki Edits: 1659
What is the mileage on the transmission? If yu know
Was the old fluid real dirty and smell burned when the service work was performed?
Is the fluid level correct?
The lazy reverse could be hard seals, worn out clutch pack.
The fluid out the dipstick tube is usually an indication of a serious problem if the vent is not plugged up
The Following User Says Thank You to Crosley For This Useful Post:
4x4blazer (07-30-2012)
