Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 4l60e started slipping
Old 08-09-2012, 09:07 PM
Crosley's Avatar
Crosley Crosley is offline
Wiki Edits: 1659
Originally Posted by 4x4blazer View Post
i figured id try something to se if it would work, i added more fluid and took it for a short drive, it did great, didnt slip and when i pulled back in the yard, i checked the level in park at idle, yes it was overfilled quite a bit but fluid didnt come out of the dipstick tube until i shut the engine off? maybe this could help diagnose it better? yes i know its not good to overfill but im not leaving it overfilled just as an experiment. maybe you guys could help me save a few bucks, thanks in advance..
I've seen early design filters installed in 4L60e trans with factory deep pan.. the filter falls out of the pump.
2002 truck - SUV would need the deep plastic filter to match the factory deep pan
The Following User Says Thank You to Crosley For This Useful Post:
4x4blazer (08-10-2012)
