4l60e swap - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-21-2011, 12:47 PM
4l60e swap
hey everyone im new to the forum and needed some info and this seems like a great place to get some help.
the trans went out in my 1990 c3500(th400). i have a 1993 suburban with 4l60e. i know this trans is electronically controlled but i have the complete suburban is there any way to use the computer from the suburban to make the trans work in the c3500. thanks for any help.
Old 08-23-2011, 12:59 AM
Are both trucks 5.7 engines? If so and if you really want the 4l60e in the 90 you could swap the engine harness and computer, trans harness and trans from the 93 into the 90.
You might have to swap a few of the sensors on the engine as the wiring plugs might be different on one or two of them.
Old 08-23-2011, 12:22 PM
4L60E isn't strong enough for a beast like a C3500. The TH400 tells all, even cost conscious GM couldn't bring themselves to put the 4 speed 700R4 which is simply the mechanically controlled version of the 4L60E into that truck.
The modern heavy duty replacement for the TH400 is the 4L80 anything lighter will have you back under there in no time.
Bogie
4L60E swap question cyclopsblown34 Transmission - Rearend 8 03-11-2010 10:40 AM
700R for 4L60E swap? flynbrian48 Transmission - Rearend 6 01-29-2009 10:56 PM
4l60e swap onto olds 350? rawcut Transmission - Rearend 5 07-01-2007 06:49 AM
4l60e year swap j_labossiere Transmission - Rearend 5 10-06-2004 04:59 AM
4L60E Trans Swap MI2600 Transmission - Rearend 3 07-12-2003 11:36 PM
