4L60E swap to an 700R4 - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-16-2011, 02:16 PM
I have a 99 Yukon 4 wheel drive with an 4L60E trans that is starting to act up. Is it possible to replace with a non electronic 700R4 out of an earlier 4 wheeler and use my transfer case. I realize the computer will go nuts trying to figure out what I done, but will cross that bridge when I get there.
Old 06-16-2011, 04:06 PM
SSedan64's Avatar
IMHO I don't think you want to cross that Bridge.
It may be possible with swapping the ECM from a Manual Trans vehicle so it's not looking for all the 60E's input.
Old 06-16-2011, 05:16 PM
My main concern is mating the transfer to an 700R4, Its my understanding the cases are the same. If I do the trans swap then i'll change intake and distributor with a tried and true Q-jet.
Old 06-16-2011, 05:27 PM
SSedan64's Avatar
It will work as long as the 700R4/4L60 has the correct length & spline Output Shaft to mate to the Transfer case.
You'll need to setup a TV cable & Bracket for the 700R4/4L60 Trans also.
from 700r4 to 4l60e rarodgers Transmission - Rearend 4 02-13-2011 06:57 PM
4l60e to 700r4 razorshotglass Transmission - Rearend 4 09-24-2009 11:45 AM
4l60e to 700r4 crussell85 Transmission - Rearend 2 05-21-2009 07:01 PM
700r4 to 4L60E swap chevy_c10 Transmission - Rearend 19 05-10-2009 09:30 AM
700r4 and 4l60e jadejoky28 Transmission - Rearend 4 04-01-2009 09:18 PM
