4l60e swap onto olds 350? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-30-2007, 10:59 PM
anyone know if this is possible? i have a 350 rocket going into a 69 cutlass. not going to be f.i., so what will i need other than adapter plate and trans computer? where can i get the computer? thanks for any help at all.
Old 06-30-2007, 11:30 PM
jakeshoe's Avatar
Why do you want to use the electronically controlled version on a carbed engine?
It is possible, but I personally would use the 200-4R, as it will bolt right up without an adapter.
The adapters are cheesy if you ask me. You only have 2 of the original bolts holding it to the block, and then the other 4 are attached to what amount so thick sheetmetal.
You could use a 700-r4 if you don't mind the adapter.
Old 06-30-2007, 11:36 PM
re:4l60e swap
thanks for the info. what are common cars that 200r4 came in? again this is for an olds 350.
Old 06-30-2007, 11:41 PM
jakeshoe's Avatar
200-4Rs commonly came in the Buick Grand Nationals, mid sized Olds, Buicks, some Chevy's, and RWD Cadillacs from 1981-1990.
Most of the "G-Body" cars or metric cars as they are called came with them. Buick Regals, Monte Carlos, Cutlass's, etc.
They are fairly common and work good IF they are properly setup. I wouldn't recommend trying to install a wrecking yard or even stock rebuilt unit for performance use behind any V8 but a few mods and a quality rebuild and they work well.
I used one behind the 427 BBC in my '69 Chevelle for a couple of years as a test mule for my build technique.
It was a nice setup.
Old 07-01-2007, 12:12 AM
re: 4l60e swap onto olds 350?
thanks much. now i can sleep easier and keep the 4l60e on the lt1 and drop them in the elco. thanks again.
Old 07-01-2007, 06:49 AM
if you decide you don't want the cutlass anymore I can take it off your hands
Chevy 350 engine swap – motor mount question 78transam Engine 4 06-04-2007 05:57 PM
350 Olds 84montess Engine 8 08-04-2006 10:07 PM
231 engine swap with buick 350 Hot_Rod_Faith Engine 1 12-20-2003 12:20 PM
Help with 305 to 350 swap tom_scott Engine 3 03-08-2003 06:34 PM
