4L60E swap Questions - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-17-2012, 11:57 AM
slowride59's Avatar
Takin' It Easy
Hi All, Hope everyone is doing good. I just have a couple short questions. I have a 1995 GMC Sierra EC Z71 4X4. It has the 4L60E Trans. in it now that has the neutral safety/backup light switch connected to the outside of the housing. I have a 4L60E trans. without the included neutral safety/backup light switch on the side. Other than the obvious that the neutral safety and back up lights will not work would there be any other problems stemming from this swap? I am doing the swap because I no longer have 2nd or passing gear anymore in the one now in the truck . Thanks to any and all that reply, And have a good one!
Old 03-17-2012, 12:51 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
You will find that is a MLPS = Manual Lever Position Sensor. It tells the PCM where the shifter location / gear selected.
You also need to be careful of what year the replacement 4L60e is.
If the replacement trans case has the bolt / threaded spuds for the MLPS , you can change the shift shaft. that may be too involved for a DIY in some situations
Old 03-18-2012, 06:59 AM
slowride59's Avatar
Takin' It Easy
4L60E Swap
Thank You For your response. The replacement trans. I have is suppose to be a 1996. It has the 4 bolt assembly pattern for the transfer adapter. I knew to look for that and yes it does have the threaded holes to mount the elect. unit on to it. I have no problem in changing the shaft. Which that was my first thought about it but I wanted to check with people on here first. Could you tell me what other possible things to check to make sure this swap will work? Thank You Again , Tony
Old 04-12-2012, 11:20 PM
fast68's Avatar
likes chevy trucks & boobies
well according to interchange and everything is iver seen and been through and such over the years 1995 was a one year transmission due to electrical differences etc
1993 1994 go together
1996 1997 go together
]and 1998 to 2000 go together
but 1995 was a standalone 4L60E
if you swap wiring and pcm from a 1996 1997 truck then the 1996 trans should work fine- again from everything ive ever read and seen and heard anyways
and, the first number/digit of the code on the sticker on the trans case is the last digit of the model year of the trans and of the truck its from
example: 9TAD
would be a 1999 model year trans and the truck its from would be a 1999 model year.
right now im dealing with this 1998 bravada smart trak i just replaced the trans with a good used lower miles one i had trouble with the range switch it broke apart when i tried to unplug it and i forgot how much the factory glued these connectors to the switch and so therefore i broke ruined the switch of course on the trans that was in the truck
well the larger connector wont plug into the switch on the replacement trans completely and the trans will not leave 2nd gear
so im sure i have a range switch to pcm signal issue
so i am gonna make sure i have full 12 volts to the pink wire at the RS connector and if so then im gonna have to swap another RS and connector pigtails here in a bit right now
and hope its good and not something else like clogged up trans fluid cooler tubes/lines
hmmmmmmmmm
for some reason though the 98 bravada RS larger connector has one less wire/pin than all the other 1995 to 03 years ones out there
not sure how or why
the connectors are supposed to be 7 and 4 wires each
why the 98 has one less i have no idea humm
i guess i just will ignore the extra wire on the pigtail and let it be free and unused.
hmmmmmmmm.,,.,.,.
good luck!
questions about controlling 4L60E SSBlazer Transmission - Rearend 5 03-28-2011 04:50 PM
4L60E questions fatnlow Transmission - Rearend 2 10-18-2010 05:35 PM
93 4l60e to 89 700r4 questions Bumper Thumper Transmission - Rearend 4 06-06-2007 01:07 PM
4L60E questions??? Decotoxiver Transmission - Rearend 6 02-26-2006 08:27 AM
questions about 4l60e 85ta383 Transmission - Rearend 3 04-10-2005 08:27 AM
