4L60E TCC Slipping when cold only - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 11-14-2010, 07:19 AM
Crosley's Avatar
Wiki Edits: 1659
I have used hundreds of the TransGo kits related to PWM lock up systems and not seen any damaged converter clutches
Sonnax products are quality stuff. Some of it is too labor intensive and tooling expensive
  #17 (permalink)
Old 11-19-2010, 11:54 AM
Have a tech 2 for the weekend need help to set it up correct.
What do I need to scan?
  #18 (permalink)
Old 11-19-2010, 12:01 PM
Originally Posted by Crosley
Down shift from what gear to ? .
Vehicle speed? On a Hill ?
Constant throttle and the trans down shifts for no reason?
You have a Tech 2 Scanner? What does it tell you? Live data stream scans?
Hello Crosley.
I have a Tech2 scanner for the weekend and I was looking for parameters I have to observe.
Here is my table what it should do?
I did not observed some weird switching on the scan tool, but I can see negative TCC speed.
Also I see tranny temperature, and I can do a snap shot.
Which parameter can give me good data to localize the failure?
SOL 1-2; 3-4 SOL 2-3 3-2 CONT SOL "Torque Converter
Clutch Solenoid"
1st ON 7V ON 7V OFF
2nd OFF ON 7V OFF
3rd OFF OFF OFF
"3rd Clutch
Converter Applied" OFF OFF ON 7V
4th TCC Applied ON 7V OFF ON 7V
  #19 (permalink)
Old 11-19-2010, 12:11 PM
Here my shift voltages which seems to be OK on the Tech2
  #20 (permalink)
Old 11-19-2010, 02:21 PM
Look at the schematic. The computer not only provides a signal voltage but in several cases a relay to ground as well. A voltage applied to the actuation solenoid from the computer would not actuate the solenoid unless the ground was also provided. For the TCC there is also a temp switch inside the trans, they will hang up open which will prevent the ON signal voltage from reaching the solenoid. When this is dysfunctional the trans should shift 1 thru 4 normally but will only actuate the TCC whenever, or if-ever, the switch happens to close. A common quirk of this switch is that unless the trans is warmed up to an oil temp of 160 before the road speed is taken to 45 mph, it just won't close period, then you don't get lock-up till the trans temp cycles hot to stone cold to warmed up again.
Beats me, I didn't design it.
Bogie
  #21 (permalink)
Old 11-19-2010, 07:29 PM
Rexnfx's Avatar
Me too, lots of Transgo. Never had a problem with the TCC. Just something that Sonnax Tech posted to TRNW.NET
Uncle Gil, is the man
I like using Sonnax and got alot of the tooling, it helps me to feel a little more like a rebuilder instead of a parts changer Blending the two is really fun. Long as you get paid for it.
  #22 (permalink)
Old 11-22-2010, 04:04 AM
Crowsley
now I can present some better data.
Hope you can help me out.
Sorry I cannot upload the SUR file.
Here the 4L60E failure mode
I am driving constant speed,
and the 4L60E is shifting down into gear 3. The PCM still listed gear 4. You can see Engine Torque, gear ratio & engine speed changes.
Today I also got a falure code P 1870. WHen I looked inot the engine snapshot not inportant information was present which gave an indication of failure mode.
Name:	S10 transmission snapshot01.jpg
  #23 (permalink)
Old 11-23-2010, 07:30 PM
Crosley's Avatar
Wiki Edits: 1659
The PCM provides grounds for solenoid activation.
A solenoid can fail 2 ways. Fail electrically or hydraulically
Your photo indicates the PCM is commanding 4th gear
The graph indicates RPM changes that would indicate a shuttle shift from 3rd to 4th... back to 3rd , then back to 4th.
There can be multiple cause:
Wire problems = ground is lost to solenoid. Could be wire from PCM down the chassis to the trans OR wire problem inside trans case. Old wire harness inside trans can cause many problems and not all show up on scanner
Solenoid may be hydraulically failing and not maintaining 4th gear. I have seen this problem more in 4L80e trans
2-4 band may be faulty, not holding power. 4th gear servo may not be holding pressure and the 2-4 band can not maintain 4th gear.
4th gear accumilator leakage and loss of pressure allows the 2-4 band to disengage and not hold 4th.
My best guess at the moment.
code p1870 was discussed earlier.. my same comments apply
  #24 (permalink)
Old 11-24-2010, 12:01 AM
Thank you for the good advice,
Is the PCM watching the current flow thought the solenoids, or does it only monitors the level on the microcontroller.
Short to ground the controller output is pulled down to zero
Intermittancey the controller see high output.
BR
Monette999
  #25 (permalink)
Old 11-24-2010, 10:00 AM
HI Crowsley
I also read in the service manual that a bad TFP Switch can cause this problem. Have you experience high defect rate on a TFP switch?
BR
4L60e slipping in 2-4 elwrencho Transmission - Rearend 7 12-01-2009 07:09 PM
4l60e delayed shift into 3rd when it's cold outside stevo71 Transmission - Rearend 3 12-20-2008 06:03 PM
4L60E Slipping bluesman123 Transmission - Rearend 10 07-18-2008 11:21 AM
TCC error code P1860 in 4L60E tranny PilotHawK Transmission - Rearend 19 10-18-2005 02:26 PM
4L80E diesel computer 5foot2 Transmission - Rearend 2 04-09-2005 12:48 PM
