4L60E teardown oops - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-23-2004, 03:32 PM
4L60E teardown oops
Installing a 2002 Blazer 4L60E into an old jeep. Bought an advance adapters kit and tried to install using the manual. The kit requires replacing the output shaft (which fit perfect) but when I installed the input shaft and drum it didn't seem to bottom out. Here comes the oops, I used the pump to try and push it in (not my most brilliant move) now I can't get the input shaft back out. Any ideas?
Old 11-23-2004, 10:17 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Cool
I would try pulling on the input shaft
Perhaps turn the tranny on to it's bell housing to see if pulling will help the input fall out.
Sounds like you have jammed the works up purty good.
Old 11-29-2004, 10:21 AM
Thanks for all the help. It just required a firm hand and it was a clutch disc jammed that kept it from coming apart. You guys are the best.
