4l60E Teckpak A74741Q - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-06-2012, 03:24 PM
Has any one replaced this valve in the valve body using the Teckpak A74741Q to fix code P1870.
I bought a Yukon that had no reverse with high miles. After reading for one night suspected it was a bad sun gear shell . I were correct in thinking that.
So Im at the end of the rebuild and I keep reading bout this infamous code. I read in other thread that this guy who rebuilds trannys always uses a Teckpak A74741Q to remedy the code P1870 no matter if it needs it or not .
After installing mine it is just really stiff in there . It does not move or slide like the orginal valve did . The orginal valve didnt have O rings on it either. I want to make sure its suppose to be . Im guessing yes since it has multiple O rings and fluids not suppose to get by it.
I just want to make sure I dont want to rebuild this again . I dont have the time or money.
Old 04-06-2012, 09:13 PM
rick 427's Avatar
Last journal entry: 33 WILLYS
If your thumb is sore after installing the o-ringed plug and roll pin,then it's installed correctly ...it's a stiff spring they give ya.....that valve should barely move when you check it after assembly....it will also improve your lock-up application,it'll be a bit firmer.
Old 04-07-2012, 05:21 AM
This is what I replaced exactly,
Yes it was pretty tuff getting it in there. Unlike the stock piece that just slipped out . This is not my picture. And was borrowed from this great write up.
http://helpwrench.com/forums/showthr...ics-and-Tricks
Old 04-07-2012, 07:37 AM
rick 427's Avatar
yea,that kit is a little different from what I use.... thats a good set up you got there.... the kits I use comes with a a spring,and when installed,acts as a semi-blocker rod thats allready incorporated in your kit as part of the valve...That looks to be MUCH easier to install than tryin to compress that spring in the kits I use....and you don't have to use a reamer to re-size the bore before putting the new valve in... nice.
4l60e shane.,herold Transmission - Rearend 5 07-20-2010 12:15 AM
2000 4L60E to an earlier 4L60E, What do I need to change out aquaterrarv Transmission - Rearend 2 04-08-2010 06:22 PM
4l60e no first 84'Monte Transmission - Rearend 5 10-10-2009 09:37 PM
4l60e Matts99Sierra Transmission - Rearend 11 06-22-2005 03:14 PM
4l60e canadianintruder Transmission - Rearend 3 02-16-2005 05:51 PM
