4l60e third gear loss - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-01-2008, 10:20 PM
i just rebuilt this 4l60e for a 94 blazer. it drove fine for the first 100 miles then it just loss third gear i check the selanoids they ohmed out right to the book i check for a sticking vavle in the vavle body and put it back together just to find the same problem. any help?
Old 03-02-2008, 05:21 PM
if you have good 4th check your servo seals, if no 4th then you may have burnt up the 3-4 pack. the #7 checkball could be leaking also
delay going from 2nd to 3rd gear aafc Transmission - Rearend 3 12-17-2007 07:54 PM
Will not go in gear when hot oldred Transmission - Rearend 3 08-27-2007 08:16 AM
Rear end gear ratio change = spedo. cable gear change. help? turbo 350 sugar ray Transmission - Rearend 6 07-18-2007 11:32 AM
4L60E won't start in 1st gear... Augusto Transmission - Rearend 1 06-01-2006 02:09 PM
7 hours, 33 phone calls, &30 pages of Threads later... Rearend? Tranny? Need Guidance 68ChevelleFromHell Suspension - Brakes - Steering 19 01-13-2006 01:01 PM
