4L60e torque converter check? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-15-2008, 10:52 AM
fiolater w/ bad 4L60E
I just pulled it how do I tell if the torque converter if bad?
Old 03-23-2008, 06:27 AM
Oh What A Job
I Just Rebuilt One Of Those. That Has A Lock Up Torque Converter. What Is It Doing?
Old 03-23-2008, 08:29 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Take it to a converter shop for a check. Usually the converter must be cut open to see what is wrong
Old 03-23-2008, 11:53 AM
Trans
HAY SHOOT ME AN EMAIL AT ********** for more info. OR CALL MY PERSONAL CELL *********** THANKS.
Last edited by Crosley; 03-23-2008 at 02:23 PM. Reason: Violation of guidelines. Please see: general board guidelines.
Old 03-23-2008, 02:26 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
WORMY;
you posted in your introduction that you own a shop "Wormys Kustoms"
Per rules set up by Jon ( admin guy) of HR , you are not allowed to post contact information. I also explained that rule to you in a PM sent.
If you wish to help a member directly please use the PM system on Hot Rodders.
IF you are not a shop owner as you presented in your introduction... please explain.
posting rules
Torque converter question sam83k10 Transmission - Rearend 7 08-09-2007 08:23 PM
Chevy Torque Converter Swap! leejoy Transmission - Rearend 7 01-04-2007 06:55 AM
Torque converter question(s) chrisflock Transmission - Rearend 3 11-10-2006 12:41 PM
destroyed 1 torque converter hotrodjohn Transmission - Rearend 3 04-17-2005 12:23 PM
What Can I Really Expect From a High Stall Torque Converter ? white66coupe Transmission - Rearend 3 05-25-2003 06:21 AM
