4l60e torque converter locked - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-13-2010, 07:29 PM
if one of the oil seals on the main shaft got damaged when i seated the pump would that cause the torque converter to stay locked up? also i bought a remanufactured OEM converter. are there alot of bad converters that could be the problem?
Old 09-13-2010, 08:21 PM
weirdbeard's Avatar
1976 Ranchero GT
Last journal entry: Almost time for the first drive!
I can only tell you I have been through about 4 converters on my 4l60e. One lasted days and the current one lasted about 2 years. I am now selling the truck I am so fed up.
They can be bad right out of the box.
Old 09-14-2010, 07:35 PM
thank you for the response. I have taken the valve body out and rechecked it and I have gotten a new tcc solenoid and took out the fuse to find the torque converter still locked up. I just may have a bad remanufactured converter. thanks again.
Not sure on a torque converter frickenbored Transmission - Rearend 5 03-30-2010 08:02 AM
4L60e torque converter check? fiolater Transmission - Rearend 4 03-23-2008 01:26 PM
700R4 Torque Converter Flexplate Question fosterdl Transmission - Rearend 8 03-23-2008 12:03 PM
Torque Converter Question newbielike Transmission - Rearend 2 12-17-2007 05:53 PM
Torque converter, diesel vs gas pjd Transmission - Rearend 4 09-10-2005 08:52 PM
