-   -   4L60E torque converter won't unlock (http://www.hotrodders.com/forum/4l60e-torque-converter-wont-unlock-184028.html)
acdcontheroad 09-07-2010 01:33 PM
I rebuilt my 4L60E in my 1994 Chevy S10 along with buying a remanufactured OEM torque converter. The torque converter is locked up. I bought a new lock up solenoid and it still will not release. I pulled the fuse and that doesn't help. I got it to roll in gear and as long as I don't come to a complete stop it shifts good and will also go into reverse on a roll. Anybody have any ideas on what I can do next to solve this problem? :(
Crosley 09-07-2010 09:19 PM
Iwould suspect something wrong in the pump - stator area that is cross leaking oil to lock up the clutch in the converter.
Perhaps a stuck lock up valve?
:cool:
acdcontheroad 09-12-2010 06:23 PM
I TOOK THE PAN OFF AND RECHECKED THE VALVES AND NONE SEEM TO BE STUCK. iF i HAD DAMAGED ONE OF THE OIL SEALS ON THE SHAFT SEATING THE PUMP DOWN, COULD THAT BE CAUSING THE LOCK UP? i REMEMBER THE PUMP NOT SEATING AND USED A MALLET TO TAP IT DOWN. ANY POINTERS WOULD BE APPRECIATED. THANK YOU.
