4L60E torque converter won't unlock - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-07-2010, 01:33 PM
I rebuilt my 4L60E in my 1994 Chevy S10 along with buying a remanufactured OEM torque converter. The torque converter is locked up. I bought a new lock up solenoid and it still will not release. I pulled the fuse and that doesn't help. I got it to roll in gear and as long as I don't come to a complete stop it shifts good and will also go into reverse on a roll. Anybody have any ideas on what I can do next to solve this problem?
Old 09-07-2010, 09:19 PM
Crosley's Avatar
Wiki Edits: 1659
Iwould suspect something wrong in the pump - stator area that is cross leaking oil to lock up the clutch in the converter.
Perhaps a stuck lock up valve?
Old 09-12-2010, 06:23 PM
I TOOK THE PAN OFF AND RECHECKED THE VALVES AND NONE SEEM TO BE STUCK. iF i HAD DAMAGED ONE OF THE OIL SEALS ON THE SHAFT SEATING THE PUMP DOWN, COULD THAT BE CAUSING THE LOCK UP? i REMEMBER THE PUMP NOT SEATING AND USED A MALLET TO TAP IT DOWN. ANY POINTERS WOULD BE APPRECIATED. THANK YOU.
Not sure on a torque converter frickenbored Transmission - Rearend 5 03-30-2010 08:02 AM
700R4 Torque Converter Flexplate Question fosterdl Transmission - Rearend 8 03-23-2008 12:03 PM
Torque Converter Question newbielike Transmission - Rearend 2 12-17-2007 05:53 PM
Torque Converter Failure - TH350 blown81 Transmission - Rearend 1 10-16-2005 11:41 AM
Torque converter, diesel vs gas pjd Transmission - Rearend 4 09-10-2005 08:52 PM
